Hi all,
I tried adding this grove in my model, and now the ruled surface in that part is going the wrong way...
I tried alternating sides for those edges but it doesn't work, and play with the radiuses and anything I could think of with no luck.
Guess It's something with not having enough space for the angle, but I just don't really understand the limitations here.
Any ideas on how to solve this / what's causing this? going a little crazy here...
Thanks!
Have you tried reducing the distance of the Tapered to Vector surface, or reducing the angle?
Your draft is causing the radius to taper down to a point, in other words it will intersect itself. Solidworks will not/cannot create a tapered to vector surface that self-intersects. So the distance will need to be short enough, or the angle shallow enough, that the surface does not self-intersect.
