Dimensions holes
Question asked by Tom Howell on Feb 19, 2016
When using the hole wizard, placing a hole on a sheet metal part, then going to dimension it's location, (before) 2016, the dimension box would pop up with the actual dimension high lighted, all you had to do was input your desired dimension, hit enter ,done, on my machine right now, doing the same process, the dimension box pops up, text is high lighted for a split second, then goes off making me have to select it again in order to change it. I've searched all over for the option to turn this off with no luck, any help would be welcome.
