I am having trouble figuring out how can I make a hole through à cylinder that I made by drawing a circle and extruding it.
Cant seem to find the right sketch to edit...
Here is my cylinder, I want to make a hole on the round surface.
Thanks!
Good question! Hopefully I understand correctly what you are trying to do.
The best way to do this is to draw a sketch on your plane that is hopefully centered on your tube. Then you can just extrude-cut through the tube.
If that's not possible, I've also used planes tangent to the outer surface of the tube and extrude-cut into the tube.
Hopefully this helps!
