Traverse Assembly at Component
Question asked by Yong Ning on Feb 18, 2016
This example shows how to traverse an assembly at the component level. It is assumed that you have an active assembly.
2010 SOLIDWORKS API Help - Traverse Assembly at Component Level Example (VBA)
http://help.solidworks.com/2010/english/api/sldworksapi/traverse_assembly_at_component_level_example_vb.htm
I use other method,  see follow code.
Function TraverseComponentArr(SwAssy As AssemblyDoc)
   Dim oDict As New Dictionary
   Dim vComp, swComp As Component2, oSwModel As ModelDoc2
      vComp = SwAssy.GetComponents(True)
      For ii = 0 To UBound(vComp)
          Set swComp = vComp(ii)
          Set oDict(swComp.GetPathName) = swComp
      Next ii
      TraverseComponentArr = oDict.Items
End Function
Private Sub ll()
   Dim swApp As SldWorks.SldWorks, swModel As ModelDoc2
       Set swModel = swApp.ActiveDoc
   Dim SwAssy As AssemblyDoc, CompArr, CompArr1
       CompArr = TraverseComponentArr(swModel)
   Dim swComp As Component2, oSwModel As ModelDoc2
       For ii = 0 To UBound(CompArr)
          Set swComp = CompArr(ii)
          Debug.Print swComp.GetPathName, swComp.ReferencedConfiguration
          If UCase(swComp.GetPathName) Like "*SLDASM" Then
              swComp.SetSuppression2 swComponentResolved
              Set oSwModel = swComp.GetModelDoc
              'Stop
              CompArr1 = TraverseComponentArr(oSwModel)
              For jj = 0 To UBound(CompArr1)
                  Set swComp = CompArr1(jj)
                  'Stop
                  Debug.Print swComp.Name2, swComp.ReferencedConfiguration
                  'SwComp.GetPathName '.GetModelDoc.GetTitle
              Next jj
       Next ii
   Dim vComp, SwComp As Component2, oSwModel As ModelDoc2
          Set SwComp = vComp(ii)
          Set oDict(SwComp.GetPathName) = SwComp
      Next ii
End Function
Function retuSheetArr(SwAssy As AssemblyDoc, SheetArr)
   Dim CompArr, CompArr1, Str
       CompArr = TraverseComponentArr(SwAssy)
   Dim rSheetArr()
       ReDim rSheetArr(UBound(SheetArr) - 1, 1)
   Dim SwComp As Component2, oSwModel As ModelDoc2
          Set SwComp = CompArr(ii)
          Debug.Print SwComp.Name, , , SwComp.ReferencedConfiguration
          Str = SwComp.Name
          Str = Split(Str, "-")(0)
          For jj = 0 To UBound(SheetArr)
              If SheetArr(jj) = Str Then
                  rSheetArr(jj - 1, 0) = Str
                  rSheetArr(jj - 1, 1) = SwComp.ReferencedConfiguration
                  Exit For
          Next jj
          If UCase(SwComp.GetPathName) Like "*SLDASM" Then
              SwComp.SetSuppression2 swComponentResolved
              Set oSwModel = SwComp.GetModelDoc
              oSwModel.ShowConfiguration2 SwComp.ReferencedConfiguration
              oSwModel.ForceRebuild3 False
              'Debug.Print oSwModel.GetPathName
              'Stop
                  Set SwComp = CompArr1(jj)
                  Str = SwComp.Name
                  For jj1 = 0 To UBound(SheetArr)
                     If SheetArr(jj1) = Str Then
                        rSheetArr(jj1 - 1, 0) = Str
                        rSheetArr(jj1 - 1, 1) = SwComp.ReferencedConfiguration
                        Exit For
                  Next jj1
              Next jj
       Next ii
       retuSheetArr = rSheetArr
End Function
Private Sub ChangViewConfiguration()
    Dim Xls As Excel.Application, Rng As Range
        Set Xls = GetObject(, "Excel.Application")
        Set Rng = Xls.Selection
    Dim Sht As Worksheet
        Set Sht = Rng.Parent
    Dim PdfDwgPath, SldDrwPath, xlsPath, openSldDrw, saveSldDrw
        xlsPath = Xls.ActiveWorkbook.Path '& "\"
        Debug.Print Sht.Name
        PdfDwgPath = xlsPath & Sht.Cells(3, 1)
        SldDrwPath = xlsPath & Sht.Cells(3, 2)
        openSldDrw = SldDrwPath & Sht.Cells(4, 2)
        'Stop
    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Set SwApp = Application.SldWorks
        Set SwModel = SwApp.ActiveDoc
    Dim SwSelMgr As SelectionMgr
        Set SwSelMgr = SwModel.SelectionManager
    Dim SwDraw As DrawingDoc
        Set SwDraw = SwModel
    Dim vSheet, SwSheet As Sheet
        vSheet = SwDraw.GetSheetNames
        SwDraw.ActivateSheet (vSheet(0))
    Dim SwView As View
    Dim SwSheetArr, SheetArr
        SheetArr = SwDraw.GetSheetNames
    Dim CompArr, SwComp As Component2
        For ii = 1 To Rng.Rows.Count
           Set SwView = SwDraw.GetFirstView
           Set SwView = SwView.GetNextView
           SwView.ReferencedConfiguration = Rng(ii, 1)
           Set SwModel = SwView.ReferencedDocument
           SwModel.ForceRebuild3 True
           SwModel.ShowConfiguration Rng(ii, 1)
           Set SwAssy = SwModel
           SwSheetArr = retuSheetArr(SwAssy, SheetArr)
           Str = SwAssy.GetTitle
           SwSheetArr(0, 0) = Left(Str, Len(Str) - 7)
           SwSheetArr(0, 1) = Rng(ii, 1)
           For jj = 0 To UBound(SwSheetArr)
               Debug.Print jj, SwSheetArr(jj, 0),
               Debug.Print SwSheetArr(jj, 1)
           Next jj
        Next ii
