New Addin Icon
Question asked by Chris Champions on Feb 18, 2016
Latest reply on Feb 19, 2016 by Sdiri Marwa
I tried to modify the sub from the Addin Template - see the code below
it's working fine with 3 items shown on the drop-down menu, however, only 2 icons are shown on the FM - what I'm missing here
Any help, please
Public Sub AddCommandMgr()
        Dim cmdGroup As ICommandGroup
        If iBmp Is Nothing Then
            iBmp = New BitmapHandler()
        Dim thisAssembly As Assembly
        Dim cmdIndex0 As Integer, cmdIndex1 As Integer, cmdIndex2 As Integer 'Add new cmdIndex2
        Dim Title As String = "VB Addin1"
        Dim ToolTip As String = "VB Addin1"
        Dim docTypes() As Integer = {swDocumentTypes_e.swDocASSEMBLY, _
                                       swDocumentTypes_e.swDocDRAWING, _
                                       swDocumentTypes_e.swDocPART}
        thisAssembly = System.Reflection.Assembly.GetAssembly(Me.GetType())
        Dim cmdGroupErr As Integer = 0
        Dim ignorePrevious As Boolean = False
        Dim registryIDs As Object = Nothing
        Dim getDataResult As Boolean = iCmdMgr.GetGroupDataFromRegistry(mainCmdGroupID, registryIDs)
        Dim knownIDs As Integer() = New Integer(2) {mainItemID1, mainItemID2, mainItemID3}
        If getDataResult Then
            If Not CompareIDs(registryIDs, knownIDs) Then 'if the IDs don't match, reset the commandGroup
                ignorePrevious = True
        cmdGroup = iCmdMgr.CreateCommandGroup2(mainCmdGroupID, Title, ToolTip, "", -1, ignorePrevious, cmdGroupErr)
        If cmdGroup Is Nothing Or thisAssembly Is Nothing Then
            Throw New NullReferenceException()
        cmdGroup.LargeIconList = iBmp.CreateFileFromResourceBitmap("Test1.ToolbarLarge.bmp", thisAssembly)
        cmdGroup.SmallIconList = iBmp.CreateFileFromResourceBitmap("Test1.ToolbarSmall.bmp", thisAssembly)
        cmdGroup.LargeMainIcon = iBmp.CreateFileFromResourceBitmap("Test1.MainIconLarge.bmp", thisAssembly)
        cmdGroup.SmallMainIcon = iBmp.CreateFileFromResourceBitmap("Test1.MainIconSmall.bmp", thisAssembly)
        Dim menuToolbarOption As Integer = swCommandItemType_e.swMenuItem Or swCommandItemType_e.swToolbarItem
        cmdIndex0 = cmdGroup.AddCommandItem2("CreateCube", -1, "Create a cube", "Create cube", 0, "CreateCube", "", mainItemID1, menuToolbarOption)
        cmdIndex1 = cmdGroup.AddCommandItem2("Show PMP", -1, "Display sample property manager", "Show PMP", 2, "ShowPMP", "PMPEnable", mainItemID2, menuToolbarOption)
        cmdIndex2 = cmdGroup.AddCommandItem2("NewItemName", -1, "NewItemHintString", "ToolTip", 0, "NewItemCallBackFunction", "", mainItemID3, menuToolbarOption)
        cmdGroup.HasToolbar = True
        cmdGroup.HasMenu = True
        cmdGroup.Activate()
        Dim flyGroup As FlyoutGroup
        flyGroup = iCmdMgr.CreateFlyoutGroup(flyoutGroupID, "Dynamic Flyout", "Flyout Tooltip", "Flyout Hint", _
              cmdGroup.SmallMainIcon, cmdGroup.LargeMainIcon, cmdGroup.SmallIconList, cmdGroup.LargeIconList, "FlyoutCallback", "FlyoutEnable")
        flyGroup.AddCommandItem("FlyoutCommand 1", "test", 0, "FlyoutCommandItem1", "FlyoutEnableCommandItem1")
        flyGroup.FlyoutType = swCommandFlyoutStyle_e.swCommandFlyoutStyle_Simple
        For Each docType As Integer In docTypes
            Dim cmdTab As ICommandTab = iCmdMgr.GetCommandTab(docType, Title)
            Dim bResult As Boolean
            If Not cmdTab Is Nothing And Not getDataResult Or ignorePrevious Then 'if tab exists, but we have ignored the registry info, re-create the tab.  Otherwise the ids won't matchup and the tab will be blank
                Dim res As Boolean = iCmdMgr.RemoveCommandTab(cmdTab)
                cmdTab = Nothing
            If cmdTab Is Nothing Then
                cmdTab = iCmdMgr.AddCommandTab(docType, Title)
                Dim cmdBox As CommandTabBox = cmdTab.AddCommandTabBox
                Dim cmdIDs(3) As Integer
                Dim TextType(3) As Integer
                cmdIDs(0) = cmdGroup.CommandID(cmdIndex0)
                TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                cmdIDs(1) = cmdGroup.CommandID(cmdIndex1)
                TextType(1) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                cmdIDs(2) = cmdGroup.ToolbarId
                TextType(2) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                bResult = cmdBox.AddCommands(cmdIDs, TextType)
                Dim cmdBox1 As CommandTabBox = cmdTab.AddCommandTabBox()
                ReDim cmdIDs(1)
                ReDim TextType(1)
                cmdIDs(0) = flyGroup.CmdID
                TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextBelow
                bResult = cmdBox1.AddCommands(cmdIDs, TextType)
                cmdTab.AddSeparator(cmdBox1, cmdIDs(0))
        Next
        thisAssembly = Nothing
