6 Replies Latest reply on Feb 25, 2016 5:21 PM by Thomas Bryant
    Points in assembly files all export same or very similar XYZ coordinates when they shouldn't
    Thomas Bryant
      I have been working on a macros to export the values from a point (or multiple points). The macro works fine in a part file/2D sketch, but when I run the macro in an assembly file, the numbers that appear are always the same set of numbers (the ones shown below) regardless of which point I select. I've used these two references, but something is obviously still wrong:
      http://help.solidworks.com/2015/English/api/sldworksapi/Transform_Point_from_Component_Space_to_Assembly_Space_Example_VB.htm
      http://help.solidworks.com/2015/English/api/sldworksapi/Transform_Coordinates_from_Sketch_to_Model_Space_Example_VB.htm
      Even when trying a different assembly file, the numbers are still a slight variation of the ones shown (i.e. 3689 as the x-coordinate). Is there something else that needs changing? Here is my code so far, as well as example screenshots of the file I'm using and the output I get from it:
      Option Explicit
      Dim xlApp As Excel.Application
      Dim xlWorkbook As Excel.Workbook
      Public Function GetModelCoordinates _
      ( _
          swApp As SldWorks.SldWorks, _
          swSketch As SldWorks.Sketch, _
          vPtArr As Variant _
      ) As Variant
          Dim swMathPt As SldWorks.MathPoint
          Dim swMathUtil As SldWorks.MathUtility
          Dim swMathTrans As SldWorks.MathTransform
          Set swMathUtil = swApp.GetMathUtility
          Set swMathPt = swMathUtil.CreatePoint(vPtArr)
          Set swMathTrans = swSketch.ModelToSketchTransform
          Set swMathTrans = swMathTrans.Inverse
          Set swMathPt = swMathPt.MultiplyTransform(swMathTrans)
          GetModelCoordinates = swMathPt.ArrayData
      End Function
      Sub Main()
          'On Error Resume Next
          Dim swAssemblyDoc As AssemblyDoc
          Dim swPartDoc As PartDoc
          Dim swSketchLine As SldWorks.SketchLine
          Dim vPt1 As Variant
          Dim vPt2 As Variant
          Dim dArr(2) As Double
          Dim i As Long
          Dim j As Long
          Dim l As Long
          Dim m As Long
          Dim n As Long
          Dim dArrUnit As Variant
          Dim bRes As Boolean
          Dim Message As String
          Dim startRow As Double
          Dim swPoint As SldWorks.SketchPoint
          Dim NumberOfSelectedItems
          Dim swSelBody As SldWorks.Body2
          Dim vModelSelPt1 As Variant
          Dim vModelSelPt2 As Variant
          Dim vModelSelPt3 As Variant
          Dim vModelSelPt4 As Variant
          Dim DEC As Double
          Dim swSketch As SldWorks.Sketch
          Dim swXform As SldWorks.MathTransform
          Dim swPt As SldWorks.MathPoint
          Dim nPt(2) As Double
          Const UnitFactor As Double = 1000 'Get from m to mm
          Set swModel = swApp.ActiveDoc
          Set swSketch = swModel.GetActiveSketch2
          Set swComp = swSelMgr.GetSelectedObjectsComponent(1)
          Set swXform = swComp.Transform2
          nPt(0) = 0#
          nPt(1) = 0#
          nPt(2) = 0#
          vPt1 = nPt
          If Not swApp Is Nothing Then
              'Set swAssemblyDoc = swApp.ActiveDoc
              If Not swModel Is Nothing And Not swMathUtil Is Nothing Then
                  NumberOfSelectedItems = swSelMgr.GetSelectedObjectCount2(-1)
                  If NumberOfSelectedItems > 0 Then
                      'initialize Excel
                      Call GetExcel
                  For l = 1 To NumberOfSelectedItems
                     Set swPoint = swSelMgr.GetSelectedObject6(l, -1)
                      Set swPt = swMathUtil.CreatePoint(vPt1)
                      Set swPt = swPt.MultiplyTransform(swXform)
                     If Not swPoint Is Nothing And Not swPt Is Nothing Then
                         'Set swSketch = swSketchLine.GetSketch
                         Set swSketch = swPoint.GetSketch
                         DEC = 6
                         dArr(0) = FormatNumber(swPoint.X * UnitFactor, DEC)
                         dArr(1) = FormatNumber(swPoint.Y * UnitFactor, DEC)
                         dArr(2) = FormatNumber(swPoint.Z * UnitFactor, DEC)
                         vPt1 = dArr
                          vModelSelPt1 = GetModelCoordinates(swApp, swSketch, vPt1)
                          'If swSelMgr.GetSelectedObjectType3(l, -1) = 1 Then
                              Message = Message & "Coordinates for Centerpoint is " & vbCrLf & "X: " & (vModelSelPt1(0)) & " mm" & " Y: " & (vModelSelPt1(1)) & " mm" & " Z: " & (vModelSelPt1(2)) & " mm" & vbCrLf
                          'End If
                          'write two lines to Excel, so startrow is counted by 2
                          bRes = WriteToExcel(((l - 1) * 2) + 1, vModelSelPt1, "Coordinates from Centerpoint")
                  Next l
                  Set swSelMgr = Nothing
                  Set swPoint = Nothing
              Set swModel = Nothing
              Set swMathUtil = Nothing
      'show the message
      MsgBox Message
      Private Sub GetExcel()
          Set xlApp = CreateObject("Excel.Application")
          xlApp.Visible = True
          Set xlWorkbook = xlApp.Workbooks.Add
      Private Function WriteToExcel(startRow As Integer, data As Variant, Optional label As String = "") As Boolean
          'get the results into excel
          With xlWorkbook.ActiveSheet
              .Cells(startRow, 1).Value = "X"
              .Cells(startRow, 2).Value = "Y"
              .Cells(startRow, 3).Value = "Z"
              .Cells(startRow, 4).Value = label
              .Cells(startRow + 1, 1).Value = data(0)
              .Cells(startRow + 1, 2).Value = data(1)
              .Cells(startRow + 1, 3).Value = data(2)
          End With
      End Function
