Logging into View on PDM Standard 2016
Question asked by Ingrid Michelson on Feb 17, 2016
Latest reply on Feb 18, 2016 by Ingrid Michelson
first post here, but I guess I'm seriously stuck. I have been trying to implement PDM Standard 2016 on our server and I have hit a roadblock. Everything goes well until I try to open the View I just created from Explorer at which point I get the following error message:
Logging into PDM Administration and checking the log it displays the following error message:
Description:
Error running query in SpDbOdbc
State=37000
Msg=[Microsoft][ODBC SQL Server Driver][SQL Server]Could not find stored procedure 'dbo.SPLI_VCSub2'.
========= LAST COMMAND ========
Exec SPLI_LoginUser N'[username]',0,0,10000,0,0
Server: WIN-G6UP6V1IANR\SWPDM
Database: SWPDM_[database]
Date: 2016-02-17 13:15:24
Module: Explorer.EXE
Function: hGetErrCode
Error code: E_EDM_DATABASE_ACCESS
Error code general description:
Could not access the item in the database.
Trying to solve this problem, I installed SQL Server Management Studio and the database does seem to contain the stored procedure in question. Running a trace with SQL server profiler does not show anything exciting. It shows two instances of "Exec SPLI_LoginUser N'[username]',0,0,10000,0,0" and then "Audit logout".
It might be relevant that entering a wrong password prompts a different error message, so it appears to work at least until the authentication bit.
I have tried reinstalling (PDM and the operating system), running on different machines but it's all the same.
setup:
  • Windows Server 2012 R2 all updates installed
  • Celeron E3400 (2 cores, 2.6 GHz)
  • 3 GB RAM
Best regards,
Ingrid
