Hi
I am still trying to learn.
I am trying this project, and two bodies overlap, and part of one body should be removed, I tried intersect, but obviously it's either the wrong tool, or I am doing it wrong.
Please take a look at the images, and the attched file.
The attached file has errors, because I removed other bodies to lighten the file, if needed I can attach the full file.
Thank you
Solution Attached
"Cut with Surface" is a good feature to use for one cut and you would have to repeat that 5 times in your model. Utilize patterning, hence intersect is the better choice. You could pattern the fin and the surface at the same time
A body delete is to remove the surfaces you used to create your geometry and get them out the way. Just hiding them is not a good work flow.
