Hi Guys, ive got a design as can be seen below, im trying to export each individual section of the tubing into a new part, so i can then save that file as an .STL and then 3D print it to build a replica model
Is this possible?
Thank you
Is this possible?
Thank you
Hi Thomas ,
is the part all one body at the moment?
you could try using the Split command to split the tubing into separate bodies and save them out as individual parts.
