Macro Loop Issue on finding documents
Question asked by Joe Pickens on Feb 16, 2016
Latest reply on Feb 16, 2016 by Joe Pickens
When i run my Module by its self it works perfectly but when i call it out and run it in a loop it works intermittently. Can anyone tell me whats wrong with it.
My Module 2 Sub Search_Excel_For_Comp() Looks at my excel sheet and pulls out the level one components and runs the part number in a file search in module 7
Module 7 does a folder loop that searches a file name in a given directory. and returns me the most recently modified document and its File path along with some document properties
here is the code for my module 2
Dim row             As Integer
Dim Str             As String
Dim Count           As Integer
Dim SWPrtLC         As String
Dim SFolder         As String
Dim SearchSte       As String
Dim Fname           As String
Dim Value           As String
SFolder = "C:\Temp\"
Value = Dir(SFolder)
'Search till there is a blank value in column A
        While Sheets("JDE BOM").Range("A6").Offset(Count, 0).Value <> ""
    'While Cells(Count + 6, "A").Value <> ""
'Only search values that have the number 1 in column E
        If Sheets("JDE BOM").Range("E6").Offset(Count, 0).Value = 1 Then
            Fname = Sheets("JDE BOM").Range("A6").Offset(Count, 0).Value
            Call Module7.ListFiles(Fname)
            Sheets("JDE BOM").Range("R6").Offset(Count, 0).Value = Fname
    Count = Count + 1
    Wend
And this is the code i am using in my module 7
Dim LatestDate      As Date
Dim FileDate        As Date
Dim Fname           As String
Dim FPath           As String
Dim FSize           As Long
Dim FType           As String
Dim FDate           As String
Dim NextRow         As Long
'Dim CompName        As String
'Force the explicit delcaration of variables
Option Explicit
Sub ListFiles(CompName As String)
'Sub ListFiles()
    'CompName = "093116010"
    'Set a reference to Microsoft Scripting Runtime by using
    'Tools > References in the Visual Basic Editor (Alt+F11)
    'Declare the variables
    Dim objFSO              As Scripting.FileSystemObject
    Dim objTopFolder        As Scripting.folder
    Dim strTopFolderName    As String
    'Dim WS                  As Worksheet
Fname = CompName
FPath = 0
FSize = 0
FType = 0
FDate = 0
    ActiveWorkbook.Sheets("Sheet1").Activate
    'Insert the headers for Columns A through F
    Sheets("Sheet1").Range("A1").Value = "File Name"
    Sheets("Sheet1").Range("B1").Value = "File Size"
    Sheets("Sheet1").Range("C1").Value = "File Type"
    Sheets("Sheet1").Range("D1").Value = "Date Created"
    Sheets("Sheet1").Range("E1").Value = "Date Last Accessed"
    Sheets("Sheet1").Range("F1").Value = "Date Last Modified"
    'Assign the top folder to a variable
    strTopFolderName = "C:\Temp"
    'Create an instance of the FileSystemObject
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    'Get the top folder
    Set objTopFolder = objFSO.GetFolder(strTopFolderName)
    'Call the RecursiveFolder routine
    Call RecursiveFolder(objTopFolder, True, Fname)
    NextRow = Cells(Rows.Count, "A").End(xlUp).row + 1
                Cells(NextRow, "A").Value = Fname
                Cells(NextRow, "B").Value = FSize
                Cells(NextRow, "C").Value = FType
                Cells(NextRow, "F").Value = FDate
                Cells(NextRow, "E").Value = FPath
                Sheets("JDE BOM").Range("S6").Offset(Count, 0).Value = Fname
                NextRow = NextRow + 1
                Count = Count + 1
    'Change the width of the columns to achieve the best fit
    Columns.AutoFit
Sub RecursiveFolder(objFolder As Scripting.folder, includeSubfolders As Boolean, CompName As String)
    Dim objFile         As Scripting.file
    Dim objSubFolder    As Scripting.folder
    Dim Fname           As String
    Fname = CompName
    'Find the next available row
    'Loop through each file in the folder
    For Each objFile In objFolder.Files
        If Mid(objFile.Name, 1, Len(objFile.Name) - 7) = CompName Then
            If Right(objFile.Name, 6) = "sldprt" Or Right(objFile.Name, 6) = "sldasm" Or Right(objFile.Name, 6) = "SLDPRT" Or Right(objFile.Name, 6) = "SLDASM" Then
                LatestDate = objFile.DateLastModified
                If LatestDate > FileDate Then
                FileDate = LatestDate
                Fname = Mid(objFile.Name, 1, Len(objFile.Name) - 7)
                FSize = objFile.Size
                FType = objFile.Type
                FDate = objFile.DateLastModified
                FPath = objFile.Path
    Next objFile
    'Loop through files in the subfolders
    If includeSubfolders Then
        For Each objSubFolder In objFolder.Subfolders
            Call RecursiveFolder(objSubFolder, True, CompName)
        Next objSubFolder
