Find Most resently modified document in a directory
Question asked by Joe Pickens on Feb 16, 2016
Latest reply on Feb 16, 2016 by Joe Pickens
I have this macro that finds solidworks files of a certain name in a folder and its subfolders.
what i want to add is for it to take the found files and if there are both assembly and part files i want it to ignore the part files and  if there is multiple of the file found i want it to take the on with the newest last date modified.
Right now i have it writhing the info to an excel sheet just so i can view what i am doing but this macro will have to be able to run without writing to excel.
'Force the explicit delcaration of variables
Option Explicit
Sub ListFiles()
    'Set a reference to Microsoft Scripting Runtime by using
    'Tools > References in the Visual Basic Editor (Alt+F11)
    'Declare the variables
    Dim objFSO As Scripting.FileSystemObject
    Dim objTopFolder As Scripting.folder
    Dim strTopFolderName As String
    'Insert the headers for Columns A through F
    Range("A1").Value = "File Name"
    Range("B1").Value = "File Size"
    Range("C1").Value = "File Type"
    Range("D1").Value = "Date Created"
    Range("E1").Value = "Date Last Accessed"
    Range("F1").Value = "Date Last Modified"
    'Assign the top folder to a variable
    strTopFolderName = "C:\Temp"
    'Create an instance of the FileSystemObject
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    'Get the top folder
    Set objTopFolder = objFSO.GetFolder(strTopFolderName)
    'Call the RecursiveFolder routine
    Call RecursiveFolder(objTopFolder, True)
    'Change the width of the columns to achieve the best fit
    Columns.AutoFit
Sub RecursiveFolder(objFolder As Scripting.folder, includeSubfolders As Boolean)
    Dim objFile         As Scripting.file
    Dim objSubFolder    As Scripting.folder
    Dim NextRow         As Long
    Dim LatestDate      As Date
    Dim FileDate        As Date
    Dim FName           As String
    Dim FPath           As String
    Dim FSize           As Long
    Dim FType           As String
    Dim FDate           As String
    'Find the next available row
    NextRow = Cells(Rows.Count, "A").End(xlUp).row + 1
    'Loop through each file in the folder
    For Each objFile In objFolder.Files
        If Mid(objFile.Name, 1, Len(objFile.Name) - 7) = 168131000 Then
            If Right(objFile.Name, 6) = "sldprt" Or Right(objFile.Name, 6) = "sldasm" Or Right(objFile.Name, 6) = "SLDPRT" Or Right(objFile.Name, 6) = "SLDASM" Then
                FName = Mid(objFile.Name, 1, Len(objFile.Name) - 7)
                FSize = objFile.Size
                FType = objFile.Type
                FDate = objFile.DateLastModified
                FPath = objFile.Path
                Cells(NextRow, "A").Value = FName
                Cells(NextRow, "B").Value = FSize
                Cells(NextRow, "C").Value = FType
                Cells(NextRow, "F").Value = FDate
                Cells(NextRow, "E").Value = FPath
                NextRow = NextRow + 1
    Next objFile
    'Loop through files in the subfolders
    If includeSubfolders Then
        For Each objSubFolder In objFolder.Subfolders
            Call RecursiveFolder(objSubFolder, True)
        Next objSubFolder
