Why doesn't MacroFeatureData::SetSelections or SetSelections2 work in C#
Question asked by Johannes Kronberger on Feb 16, 2016
Latest reply on Feb 16, 2016 by Artem Taturevych
I have the following code which runs when my property manager closes.
       protected override void OnClose(swPropertyManagerPageCloseReasons_e reason)
             if (reason ==  swPropertyManagerPageCloseReasons_e.swPropertyManagerPageClose_Okay)
                if(State==StateEnum.Edit)
                    IBody2[] objects = this.MacroFeature.SelectionMgr.GetSelectedObjects((type,mark)=>type==swSelectType_e.swSelSOLIDBODIES)
                        .Cast<IBody2>()
                        .ToArray();
                    //this.MacroFeature.SwFeatureData.SetSelections(ObjectArrayToDispatchWrapper(objects),null);
                   this.MacroFeature.SwFeatureData.SetSelections(objects,null);
                    Debug.Assert(this.MacroFeature.SwFeatureData.GetSelectionCount()==objects.Length);
                    this.MacroFeature.Write();
                    MacroFeature.ModifyDefinition();
                else
                    IBody2 editBody = null;
                    const int opts = 0;
                    FeatureManagerExtensions.InsertMacroFeature
                        (this.MacroFeature.ModelDoc.FeatureManager, featureName, editBody, opts, this.MacroFeature.Database);
            }else if (reason == swPropertyManagerPageCloseReasons_e.swPropertyManagerPageClose_Cancel)
                MacroFeature.ReleaseSelectionAccess();
I have previously called AccessSelections before raising the property page.  When I call SetSelections or SetSelections2 with a normal array or an array of DispatchWrappers the selection count does not change. See the Debug.Assert that tests this.
If I ignore the assert and let the feature commit then I find that the selections have not changed. What may I be doing wrong?
For info my Edit method that raises the property page is
       protected override object Edit()
            ppage = new SamplePropertyPage(this, State);
            if (SwFeatureData != null)
                var result = SwFeatureData.AccessSelections(ModelDoc, null);
                if(!result)
                    throw new Exception("Expected to get true");
                    object objects;
                    object objectTypes;
                    object marks;
                    object drViews;
                    object componentXForms;
                    SwFeatureData.GetSelections3(out objects, out objectTypes, out marks, out drViews, out componentXForms);
                    if(objects!=null)
                        var objectsArray = ((object[])objects).Cast<IBody2>().ToList();
                        swSelectType_e[] typesArray = (swSelectType_e[])objectTypes;
                        ModelDoc.ClearSelection2(true);
                        foreach (var feature in objectsArray)
                            feature.Select2(true, null);
            ppage.Show();
            return null;
