Has anyone used the case sensitive check box on the conditional jump window in dispatch. I am assuming that when checked if the case of the variables does not match then the variable considered as not matching.
Below is how I have the jump set. %d_Prefix% is pulled from the file card and is upper case. %d_New_Prefix% from an edit box entered by the user and the case depends on what the user enters.
My goal is to insure the user enters upper case letters. However, if the user enters lower case the jump goes to the wrong label (not the one set in this jump). If the user enters upper case letters the jump works properly.
Any ideas on why this might be happening?
Can you show the entire script, especially what jump goes to the label you're seeing lower case stuff go to.
