BKBenedict Kent16/02/2016
I'm trying to make a drip tray using sheet metal in Solidworks. The drip tray is of a type where the drain is in the centre and therefore requires that the base has pan is an upside down pyramid shape, very slight mind you. I looked through and saw someone else had something similar, I downloaded the example someone did and figured it out thinking this is what I want. The thread is question is this
So this is the stage I am at, and I'm struggling how I make this into a sheetmetal part.
I've also attached the part. If anyone can help much appreciated.
