We are in the process of designing a new Stainless Steel Label/Nameplate that gets mounted on our different pcs of furniture and I would like to know the best process to use.
Please list your leads here,
Thanks - John
East Coast - USA
Thanks - John
East Coast - USA
hi John,
If you're looking at adding some depth to your badge coined badges look pretty smart and are fairly economical to produce. LaFrance Corp - Coined Aluminum
That is the exact look I am designing the first phase, with the letters a whole lot less bold, something crisp & elegant is the design concept at the moment..
John,
I've used these guys in years past. http://www.mcloone.com/products/nameplates/ They have other pages of plates that may fit your need etc better.
My dad used to have a mechanical engraving business. I have engraved the gold key to the city when President Nixon came here, sight tubes for 50mm cannons going to Viet Nam If it was 30 years ago I might have been able to help you out more! LOL!
Thanks Bernie - 30 yrs ago lol
I know years ago we got something etched with a plasma and it was really rough especially the arc starting point, so I was a little apprehensive with that process. I did suggest to the owner here that engraving or etching would be the way to go, however the technology changes over the years could have changed the appearance of the plasma etching.
One idea
Hi John,
From recent experience, etching is most durable and long-lasting, but from some angles the words almost disappear.
Laser marking with Cermark gave the darkest print, nicely visible from all angles.
Try google image search for Cermark Stainless
My company has various products made from hardened 416SS that are laser marked. We blast the surface with extremely fine glass bead to give a frosted/matte finish before laser marking. You can only get black engraving on a metallic background.
The type of laser and the person programming the laser makes a big difference. If you don't like the initial results one or both of these 2 things needs to change to get improvement.
Also, colored anodizing on aluminum plates makes a very nice looking laser marked plate. This creates a whitish aluminum colored engraving with background of any color you want. The contrast is very good with colored anodized plates.
hei'ya John,
I'm guessing that budget limits
and styles of product may put
this suggestion in deep left field
The Home of Porcelain Enameled Steel Signs
any hoo my 2cts worth-
'cos I'm way ol'school
have a good'n kelef
John,
My day job is as a Design Engineer, hence my use of SolidWorks. However, my wife and I own an engraving and awards business. This type of customized plate you describe seems to be a perfect application for laser engraved anodized aluminum plate or as some posts above mention a stainless plate marked with CerMark or Thermark. I believe the quality would be inline with what you are looking for. I would happy to discuss with you further offline, if you are interested.
Thank you Brett Buzzy it was a longer process, but we finally decided on a style that works and then you sent us a fine sample to match what we needed, service was much appreciated, thank you for your help. Thermark is an awesome process, high quality for a crisp clean look.
Thanks again
John,
