All,
I've just upgraded to 2016 SP 1.0. In the past, I've been able to add a "logo" (I use a .png file) to a surface using Appearances, then rotate it to the correct position. In this newer version, I am only given the corner pts & midpoints that adjust the size of the logo. The logo is locating 90 degrees off of what I need and I can't figure out how to rotate it. Any ideas?
Deanna
Deanna,... it's probably set to "automatic", change it to surface or projection and you should get the rotation option.... btw,.. what about using a decal?
