Read text from TitleBlock in drawing
Question asked by Divyanshu Bhardwaj on Feb 15, 2016
Latest reply on Feb 15, 2016 by Divyanshu Bhardwaj
I'm trying to read some text from TitleBlock in a drawing sheet using VBA. The Problem i'm having is the 'Object not set'. I don't know why it's happening. Having hard time.
Code:
Set swDraw = swApp.ActiveDoc
'swDraw.EditTemplate
Dim swSheet As SldWorks.Sheet
Set swSheet = swDraw.GetCurrentSheet()
Dim sheet_name As String
sheet_name = swSheet.GetName()
Dim swTitle As SldWorks.TitleBlock
Set swTitle = swSheet.TitleBlock()
Dim note_count As Integer
'note_count = swTitle.GetNoteCount()         '<<<<<<<If made active, its also giving the same error
Dim vNote As SldWorks.Note
'ReDim vNote(note_count)
Set vNote = swTitle.GetNotes                     '<<<<< Here i am having the problem. The return type is array of notes, even i make it array of note, gives me error.
'Dim i As Integer
'Dim note_name As String
'Dim note_text As String
'For i = 0 To UBound(vNote)
'    Dim swNote As SldWorks.Note
'    Set swNote = vNote(i)
'    note_name = swNote.GetName()
'    note_text = swNote.GetText()
'Next i
