NWNicholas Wilde13/02/2016
I'm trying to loop through existing concentric mates and rotation locking only certain ones. For some reason EditMate3​​ doesn't want to enable the Lock rotation. I can get the same macro to uncheck the Lock Rotation by setting LockRotation to false, but when I set it to true it does nothing. Any help is appreciated.
I'm using the Edit Mate Example as a base.
I find it ironic that the SolidWorks Jive forum doesn't support VBA .
Option Explicit
    Dim swApp               As SldWorks.SldWorks
    Dim swModel             As SldWorks.ModelDoc2
    Dim swFeat              As SldWorks.Feature
    Dim swBomFeat           As SldWorks.BomFeature
    Dim swSubFeat           As SldWorks.Feature
    Dim swBOMAnnotation     As SldWorks.BomTableAnnotation
    Dim swBOMFeature        As SldWorks.BomFeature
    Dim swTableAnn          As SldWorks.TableAnnotation
    Dim blnRtn As Boolean
    Dim swMateEnt()             As SldWorks.MateEntity2
    Dim i As Integer
    Dim swMate                  As SldWorks.Mate2
    Dim nRetVal As Long
    Set swModel = swApp.ActiveDoc
    Set swFeat = swModel.FirstFeature
    Do While Not swFeat Is Nothing
        If swFeat.GetTypeName2 = "MateGroup" Then
            Set swSubFeat = swFeat.GetFirstSubFeature                           ' Get the features of the drawing
            Do While Not swSubFeat Is Nothing
                ' If swSubFeat.GetTypeName2 = "MateConcentric" Then
                If swSubFeat.Name = "Concentric165" Then
                    Debug.Print "  Feature Name : " & swSubFeat.Name
                    Debug.Print "  Feature Type Name : " & swSubFeat.GetTypeName
                    Set swMate = swSubFeat.GetSpecificFeature2
                    For i = 0 To swMate.GetMateEntityCount - 1
                        blnRtn = SelectMateEntity(swApp, swModel, swMate.MateEntity(i), 1)
                    Next i
                    blnRtn = swSubFeat.Select2(True, 0)
                    swModel.EditMate3 _
                        swMate.Type, _
                        swMate.Alignment, _
                        swMate.Flipped, _
                        0#, _
                        swMate.MaximumVariation, _
                        swMate.MinimumVariation, _
                        0#, _
                        0#, _
                        0#, _
                        False, _
                        True, _
                        0, _
                        nRetVal
                    Debug.Print "nRetVal: " & nRetVal
                    blnRtn = swModel.EditRebuild3
                    Exit Sub
                Set swSubFeat = swSubFeat.GetNextSubFeature
            Loop
        Set swFeat = swFeat.GetNextFeature
    Loop
Function SelectMateEntity(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swMateEnt As SldWorks.MateEntity2, nMark As Long) As Boolean
    Dim swEnt                   As SldWorks.Entity
    Dim swSelMgr                As SldWorks.SelectionMgr
    Dim swSelData               As SldWorks.SelectData
    Dim bRet                    As Boolean
    Select Case swMateEnt.ReferenceType
        Case swMateEntity2ReferenceType_Point, _
                swMateEntity2ReferenceType_Line, _
                swMateEntity2ReferenceType_Circle, _
                swMateEntity2ReferenceType_Plane, _
                swMateEntity2ReferenceType_Cylinder, _
                swMateEntity2ReferenceType_Sphere, _
                swMateEntity2ReferenceType_Cone, _
                swMateEntity2ReferenceType_SweptSurface
            Set swSelData = swSelMgr.CreateSelectData
            Set swEnt = swMateEnt.Reference
            swSelData.Mark = nMark
            bRet = swEnt.Select4(True, swSelData)
            SelectMateEntity = bRet
            Exit Function
        Case swMateEntity2ReferenceType_Set, _
                swMateEntity2ReferenceType_MultipleSurface, _
                swMateEntity2ReferenceType_GenSurface, _
                swMateEntity2ReferenceType_Ellipse, _
                swMateEntity2ReferenceType_GeneralCurve, _
                swMateEntity2ReferenceType_UNKNOWN
        Case Else
    End Select
    SelectMateEntity = False
End Function
