I installed student edition, says it cannot find license. I go into the License manager and I am told that SW "could not get information from this server: " I have 25734@myserver in as my server. Is this incorrect?
See attachment for a better description please.
Hi Jeffrey,
Are you installing Student edition or EDU edition? If it is student edition you should be using a serial number starting with 9020. Also student edition are standalone license serial number and does not require SNL manager and SNL server for licensing.
Only in case of EDU edition, it requires a license server to connect and get license. The default syntax for defining license server is 25734@<serve name> i.e. the "machine name" on which license server is installed.
