Try this as a basis for a more complete tool. There are so many ways to instance forming tools that it would take some time to implement them all. Assuming you do one forming tool per feature and only use mirrored features, linear and circular patterns, this would cover it.
Function featureIsFormTool(swFeature As Feature) As Boolean
If swFeature.GetTypeName2 = "FormToolInstance" Then
featureIsFormTool = True
Else
featureIsFormTool = False
End Function
Function GetMirrorPatternCount(swFeature As Feature) As Integer
Dim formToolCount As Integer
Dim swMirrorPatternFeatureData As MirrorPatternFeatureData
Set swMirrorPatternFeatureData = swFeature.GetDefinition
Dim patternArray As Variant
patternArray = swMirrorPatternFeatureData.PatternFeatureArray
For i = 0 To UBound(patternArray)
Dim f As Feature
Set f = patternArray(i)
If featureIsFormTool(f) Then
Dim patternCount As Integer
Dim d1Count As Integer
Dim skippedCount As Integer
d1Count = swMirrorPatternFeatureData.GetPatternFeatureCount
formToolCount = d1Count
Next i
GetMirrorPatternCount = formToolCount
End Function
Function GetCircularPatternCount(swFeature As Feature) As Integer
Dim swCircularPatternFeatureData As CircularPatternFeatureData
Set swCircularPatternFeatureData = swFeature.GetDefinition
If swCircularPatternFeatureData.BodyPattern Then
formToolCount = 0
Else
patternArray = swCircularPatternFeatureData.PatternFeatureArray
Dim f As Feature
d1Count = swCircularPatternFeatureData.TotalInstances
skippedCount = swCircularPatternFeatureData.GetSkippedItemCount
formToolCount = d1Count - skippedCount - 1 'subtract the seed feature
Next i
GetCircularPatternCount = formToolCount
End Function
Function GetLinearPatternCount(swFeature As Feature) As Integer
Dim swLinearPatternFeatureData As LinearPatternFeatureData
Set swLinearPatternFeatureData = swFeature.GetDefinition
If swLinearPatternFeatureData.BodyPattern Then
formToolCount = 0
Else
patternArray = swLinearPatternFeatureData.PatternFeatureArray
Dim f As Feature
Dim d2Count As Integer
d1Count = swLinearPatternFeatureData.D1TotalInstances
d2Count = swLinearPatternFeatureData.D2TotalInstances
skippedCount = swLinearPatternFeatureData.GetSkippedItemCount
formToolCount = (d1Count * d2Count) - skippedCount - 1 'subtract the seed feature
Next i
GetLinearPatternCount = formToolCount
End Function
Dim model As ModelDoc2
Set model = swApp.ActiveDoc
Dim fm As FeatureManager
Set fm = model.FeatureManager
Dim features As Variant
features = fm.GetFeatures(True)
Dim i As Integer
For i = 0 To UBound(features)
Dim f As Feature
Set f = features(i)
If f.IsSuppressed = False Then
Debug.Print f.GetTypeName2
'handle feature types
Select Case f.GetTypeName2
Case "FormToolInstance"
formToolCount = formToolCount + 1
Case "LPattern"
formToolCount = formToolCount + GetLinearPatternCount(f)
Case "CirPattern"
formToolCount = formToolCount + GetCircularPatternCount(f)
Case "MirrorPattern"
formToolCount = formToolCount + GetMirrorPatternCount(f)
End Select
Next i
MsgBox formToolCount & " form tool features"
Hi Michael,
I attached a model example. It's possible to get:
1. TOTAL OF FORMING TOOLS= 9
2.The number of each part: -counter sink emboss1= 3
-circular emboss1= 1
-arc lance1= 1
-counter sink emboss21= 4
Thank you very much
It would take much more development work, but you could begin from the source code I shared. You would need to add a routine to count sketch pattern points by accessing its referenced sketch.
Getting the number of form features created in one operation using multiple sketch points is a different challenge. The form tool feature does not have a definition you can access through the API. You would need to access its child features (two sketches). The first will contain the sketch points that define the total number created in that feature.
Feature names will help you determine the type of forming tool.
Hopefully that's enough to help you work through the remaining detail!
Mike
On linear pattern:
'If swLinearPatternFeatureData.BodyPattern Then
formToolCount = 0
'Else
Dim f As Feature
Next i
'End If
End Function
If i have a situation like in image... How can check if a feature have in child a pattern??
After this macro it takes only 2 forming tools because in pattern is set 2 instances... i want to do something like this:
If feature has a child patern then: TOTAL=number of instances from liniar pattern * parent feature skech points
Hello Hrituc,
Here are a couple routines you could add to the tool. These also show how to get parent features and determine what type of feature it is. For example, "ProfileFeature" is the type name for a sketch. As seen in the main procedure, "FormToolInstance" is the type name of a forming tool feature.
'--------- Gets the number of points in the parent sketch of a forming tool feature ------------------
Private Function GetSkPointCount(swFeature As Feature) As Integer
Dim ptSketch As Sketch
Dim sketches As Variant
sketches = swFeature.GetParents
Dim ptCount As Integer
Dim i As Integer
For i = 0 To UBound(sketches)
Dim skFeat As Feature
Dim sk As Sketch
Set skFeat = sketches(i)
If skFeat.GetTypeName2 = "ProfileFeature" Then
Set sk = skFeat.GetSpecificFeature2
ptCount = sk.GetSketchPointsCount2 - 2 'sketch always has 2 extra points on a centerline
Next i
GetSkPointCount = ptCount
End Function
'--------- Gets the number of points in the parent sketch of a sketch pattern -----------------
Function GetSkPatternCount(swFeature As Feature) As Integer
Dim swSketchPatternFeatureData As SketchPatternFeatureData
Set swSketchPatternFeatureData = swFeature.GetDefinition
patternArray = swSketchPatternFeatureData.PatternFeatureArray
Dim f As Feature
Dim sk As Sketch
Dim j As Integer
For j = 0 To UBound(sketches)
Set skFeat = sketches(j)
d1Count = sk.GetSketchPointsCount2
Next j
Next i
GetSkPatternCount = formToolCount
End Function
Hello Hrituc,
Dim i As Integer
Dim sk As Sketch
Next i
End Function
Dim f As Feature
Dim sk As Sketch
Dim j As Integer
Next j
Next i
End Function
