When making a hole sketch, the 1st thing I need to do often is to put a construction rectangle to place the points. Unfortunately, I rarely need the point in the center, the but center-placed rectangle also places a point which is converted to a hole.
How can I make a center-referenced construction rectangle without it placing the hole in the middle?
Many people here will disagree, but you can do what I do. Create the rectangle in a separate sketch first and leave it visible. Activate the Hole Wizard function and place the points where wanted coincident with the separate sketch. Then hide the sketch. I know that creates an extra feature in the tree, but I don't care. It eliminates the issue you're talking about, and the driving sketch is always right there above the Hole Wizard feature in the tree, so it's easily accessible for editing if the design changes.
