We've recently added a task to our workflow to convert models to parasolids upon approval. When this is performed we'd like to add the revision of the model to the end of the file name i.e. <Source File Name>_Rev<Source File Rev>.x_b
When the model is revised and approved the revision increments, so if the first file name was <Source File Name>_RevA.x_b, the second is <Source File Name>_RevB.x_b
The problem we have is that we want the new file to replace the old one, but because the file name is changing the "Replace existing files" option in the Convert task doesn't work.
Is there a way to get the new file to overwrite the old, or even a way to automatically delete the old when the new is created?
I would have thought this kind of functionality would be included in EPDM, but my search so far has led me to believe it will be a somewhat complex work around.
EDIT: I know it would be easier to just not include the revision in the file name, but at this stage, that is not an option.
Slightly embarrassing...
There is a check box to also remove file from vault, without this checked it only deletes local files. All seems to be working now.
I also added a 0 (zero) as the first character in the variable Alpha. I've got the dispatch to be triggered by x_b files doing the transition to released. When it was attempting to run on revision A files the task was was failing because it couldn't figure out what it was supposed to delete. I also added a Jump into the command window, so that IF %Revision% = A then GOTO End.
It seems to be working. I had to remove the OK Message Box, otherwise the server wouldn't finish the task until the message box was OK'd.
