I'm having an issue with my tangent edges showing in assemblies. I have my settings set to remove tangent edges and they still show in the assembly. I'm referring to the assemblies and parts, not in drawings like I've seen most of the issues are with in this forum. When I select a part that is showing tangent edges and open it, once i rebuild the part the edges go away. When I return to the assembly, they are also removed. My problem is, the keep coming back on, and i would have to repeat this process if I don't want them to show.
I recently had to reset all of my system settings because PhotoView crashed every time I opened it (long story), so I don't have everything setup the way I use to have it. Is there something I'm missing other than the System Options>Display/Selection>Part/Assembly tangent edge display>Removed that I am missing. My guess is this is more of a bug, than a setting, but lets hope I'm wrong.
