I am a native Creo (Pro/E) user using SW for the past 8 months or so. I used to do a lot of surfacing in Creo for my previous job for nesting and part contours. you could make things independent once you have the surfaces you want. i would like to do this in SW so that I could get a general shape, move on, change something higher up in the model tree and not have it break things that follow it. Thanks!
Are you creating a solid from the surfaces you created and then looking to modify the solid by changing the surface contour/shape? If so, I would expect it to work provided that the surface change is not sufficiently radical to disrupt the resultant solid. If you have created the solid by knitting the surfaces, give it a try by using the "Intersect" command instead of by knitting and creating a solid.
