2 Replies Latest reply on Feb 10, 2016 7:56 AM by Erik Söderby
    Edit/replace reference entities for a point (API)
    Erik Söderby
      I'm trying to do - what I thought - a simple operation, but the struggle is real... I want to replace a reference in a point, from one spline (Spline1@3DSketch1) to another (Spline1@3DSketch2). I assume that swRefPtData.Selections is an array with reference entities and in my case I just have one entity, therefore I want to replace number 0. Works perfectly when I do it manually, so no issues with the CAD model, but nothing happens when I run the macro (I've re-written the code multiple times, can't figure out what's wrong). My code is based on this example (Ivana's answer): SolidWorks API - EditReferencePoint , but instead of changing the distance I want to change the reference entity. Does anyone have an idea?
      Here's my code:
      Set swApp = _
      Application.SldWorks
      Set Part = swApp.ActiveDoc
      boolstatus = Part.Extension.SelectByID2("Point1", "DATUMPOINT", 0, 0, 0, False, 0, Nothing, 0)
      Set swSelMgr = Part.SelectionManager
      Set swFeature = swSelMgr.GetSelectedObject6(1, -1)
      Set swRefPt = swFeature.GetSpecificFeature2
      Set swRefPtData = swFeature.GetDefinition
      boolstatus = swRefPtData.AccessSelections(Part, Nothing)
      swRefPtData.Selections(0) = "Spline1@3DSketch2"
      swFeature.ModifyDefinition swRefPtData, Part, Nothing
      Part.EditRebuild3
      Thanks in advance!
        • Re: Edit/replace reference entities for a point (API)
          Artem Taturevych
          You need to pass the array of pointers instead of names. So something like this will work:
          swRefPtData.Selections = part.FeatureByName("3DSketch2").GetSpecificFeature().GetSketchSegments()
          Artem
              Erik Söderby
              It worked in another way, by using ISetSelections. Here's the code:
              Set swApp = _
              boolstatus = Part.Extension.SelectByID2("Spline1@3DSketch2", "EXTSKETCHSEGMENT", 5.21258681764607E-02, -0.288752179158223, -0.174936389034599, True, 0, Nothing, 0)
              Set swFeature2 = swSelMgr.GetSelectedObject6(1, -1)
              Part.ClearSelection2 True
              Longy = 1
              swRefPtData.ISetSelections Longy, swFeature2
              Part.EditRebuild3
              However, I want to make the solution generic and therefore I need access to the array of reference entities. I'm trying with Debug.Print to figure out how to code, but how do I use that function when I have an array of objects? Let's say I have to reference entities in a point, "RefNo1" and "RefNo2" and I simply want to know their names. Something like this:
              For I=0 To (swRefPtData.GetSelectionsCount - 1)
              Debug.Print swRefPtData.Selections(I).GetName
              Next I
              Maybe it seems simple, but a debug function is crucial in my project.
