BGBen Galili10/02/2016
Hi.
So solidworks doesn't make sense (again)...
I have a hole (cut extrude) and after it a chamfer. (not using the hole wizard)
in the drawing hole callout, when I try to insert a tolerance to the dimension, it automaticly chooses the chamfer diameter.
as seen in the attached Pic, this is because from some weird reason the chamfer diameter is the default primary value of the callout. and its greyed out so I cant change it.
any workarounds or solutions?
Ben
