When I use the shortcuts menu (hotkey S, which I think is standard), I have a flyout sub-menu for Tables. This flyout menu is great, but it has tables I will never use (weldments, weldment cut table, etc.). How can I remove these options?
I've tried the Customize option and removed said entries from the Table option, to no effect. What am I missing?
Hi Chris,
enable the fly out menu (click S) then right click on it and customize.
You Can customize the menu different for part, assembly, drawing and sketch.
You could also use mouse Gestures if you want to speed your work up.
Leszek
