Hello
I have a basic assembly with just 2 parts and would like the small disc to rotate eccentric to the large disc. That is, it should rotate off-centre.
Is there a way to define the small disc's axis of rotation without explicitly creating a shaft?
Any help will be appreciated.
John
I'd recommend creating an axis on the small disc where you want the center of rotation (in it's Part file, not in the Assembly). Then place a sketch point on the large disc where you want the center of rotation for the small disc to be. Finally create a coincident mate between the axis and sketch point.
