4 Replies Latest reply on Feb 8, 2016 6:33 PM by Artem Taturevych
    AddRelation not working
    Joshua Linsky
      I've tried many different ways to get the AddRelation to actually add a relation, but none of them seem to work. Has anyone been able to actually use this method? I've tried looking online but I can't find very much about this. This is my code:
      Dim modelType As Long
      Dim swSkMgr As SldWorks.SketchManager
      Dim swSkRelMgr As SldWorks.SketchRelationManager
      Dim swSkRel As SldWorks.SketchRelation
      Dim swSketch As Sketch
      Dim sketchSegs() As SldWorks.SketchLine
      Type coordinates
          x As Double
          y As Double
          z As Double
      End Type
          Set swModel = swApp.NewDocument("C:\ProgramData\SolidWorks\SolidWorks 2014\templates\Part.prtdot", 0, 0, 0)
          Set swSkMgr = swModel.SketchManager
          swSkMgr.Insert3DSketch True
          Set swSketch = swSkMgr.ActiveSketch
      'This line prints "True" every time indicating that my sketch IS active
          Debug.Print (swSketch.Is3D)
          Set swSkRelMgr = swSketch.RelationManager
          'swModel.SetAddToDB (True)
          'swModel.SetDisplayWhenAdded (False)
          'Call makeModel
          Call makeModelWithRelations
          'swModel.SetAddToDB (False)
          'swModel.SetDisplayWhenAdded (True)
      Sub makeModelWithRelations()
          Dim boolstatus As Boolean
          Dim startPoint As coordinates
          Dim endPoint As coordinates
          Dim vEntities As Variant
          Dim objArray(2) As Object
          Dim segment(1) As SketchSegment
          Dim segment2(1) As SketchLine
          Dim heading As Double
          Dim relations As Integer
          For currentInstruction = 0 To UBound(GetFile.bendProg.rotation)
              If currentInstruction = 0 Then
                  startPoint = setPoint(0, 0, 0)
                  endPoint = setPoint(0, bendProg.straight(0), 0)
                  createAline startPoint, endPoint
                  Set objArray(0) = sketchSegs(currentInstruction)
                  Set segment(0) = objArray(0)
                  Set segment2(0) = objArray(0)
                  Set swSkRel = swSkRelMgr.AddRelation(segment, swConstraintType_e.swConstraintType_FIXED)
                  Set swSkRel = swSkRelMgr.AddRelation(segment2, swConstraintType_e.swConstraintType_FIXED)
                  Set swSkRel = swSkRelMgr.AddRelation(objArray, swConstraintType_e.swConstraintType_FIXED)
                'If there is a relation it will show up in between the "df" and "SG", but every time this is run all that is printed is "dfSG"
                  Debug.Print ("df" & swSkRelMgr.GetRelations(swAll) & "SG")
                  relations = swSkRelMgr.IGetAllowedRelations(1, segment2(0), 4)
                'This always prints out 17, indicating that I CAN make this line fixed
                  Debug.Print (relations)
              Else
          Next currentInstruction
      Sub createAline(ByRef startPt As coordinates, endPt As coordinates)
          Dim boolstatus As SldWorks.SketchLine
          Dim bool As Boolean
          Dim dummy1 As coordinates
          Dim dummy2 As coordinates
          dummy1 = setPoint(startPt.x, startPt.y, startPt.z)
          dummy2 = setPoint(endPt.x, endPt.y, endPt.z)
          dummy1 = convertToInch(dummy1)
          dummy2 = convertToInch(dummy2)
          Set boolstatus = swSkMgr.CreateLine(dummy1.x, dummy1.y, dummy1.z, dummy2.x, dummy2.y, dummy2.z)
          ReDim Preserve sketchSegs(currentInstruction + 1)
          Set sketchSegs(currentInstruction) = boolstatus
      Function setPoint(ByVal X2 As Double, ByVal Y2 As Double, ByVal z2 As Double) As coordinates
          Dim toSet As coordinates
          toSet.x = X2
          toSet.y = Y2
          toSet.z = z2
          setPoint = toSet
      End Function
      Function convertToInch(toConv As coordinates) As coordinates
          toConv.x = toConv.x * metersToInch
          toConv.y = toConv.y * metersToInch
          toConv.z = toConv.z * metersToInch
          convertToInch = toConv
      End Function
      The documentation for AddRelation is as follows:
      Function AddRelation( _
         ByVal Entities As System.Object, _
         ByVal RelationType As System.Integer _
      ) As SketchRelation
      Visual Basic (Usage)
      Dim instance As ISketchRelationManager
      Dim Entities As System.Object
      Dim RelationType As System.Integer
      Dim value As SketchRelation
      value = instance.AddRelation(Entities, RelationType)
      I've tried making "Entities" an array of: Objects, SketchLine, and SketchSegment and none of these seem to be what "entities" should be.
      Also, if I just try:
      Set swSkRel = swSkRelMgr.AddRelation(objArray(0), swConstraintType_e.swConstraintType_FIXED), which only references the one line I've made, solidworks just crashes
      Can anyone tell me what I'm doing wrong? I'm about at my wits end on this.
