I received a SW part file from a customer. When I try to edit a Hole wizard feature a message comes up. "The derived standard COMPANY NAME does not exist in the data base. Using the parent of this standard instead." I can just click OK and go past but I want to get the correct file in place.
Hi Gary,
Chances are your customer has created their own hole wizard standards as described in here SOLIDWORKS
If you want the hole wizard to recognise the feature on your machine you will need to request the necessary MDB file from your customer and replace your own. If they do provide theirs, back yours up first.
