i have purchased a "newish" workstation, which runs with a dualXeon 3.0 cpu, windows XP SP2, 2gb memory.The testing part (punch holder) i used, was the one from this thread :http://forum.solidworks.com/forum/messageview.cfm?catid=14&threadid=6436&enterthread=yI have a redraw time of about 300 secs, and i find it a bit (actually alot)too slow.I have tried to disable the hyperthreading in the bios, so that windowsonly can see two cpu's, and i ends up with some 302 secs wasted in redrawing timeIf i enable the hyperthreading, i ends up with 310 secs wastedApparently it's not the harddrive (10K scsi disks) speed there's the problem, as SW doesn'tuse them during redrawing (not much atleast, i can't see if it's windowsor SW who is acessing the disks a little bit from time to time)I get the same results redraw results, whenever i'm using SW 2007(sp4) or 2008.Does anyone have any ideas of how to cut off seconds in wasted time??Tia.Michael Clay
Are you Opening the file over the Network or Locally?
If over the Network, copy the file to a Local Drive and try again.
