I have got two solid bodies I want to combine. However, for some reason, they don't perfectly match with each other. Interescting or combining them does not fix this.
How can I merge the bodies and have solidworks fill the gaps where the matches aren't perfect ? I will eventually add a filet so that the match looks nice.
Thanks for your help.
All the best,
A.
Hey John,,, Combine the bodies then do a "DeleteFace" (with Delete and Patch) on the faces then things should match up like you would like to see.
I have included a file that I have done this with the surfaces I think you want patched.
Edit:... I think I found another face to patch so I attached another file. This is easier than you may think.
