How to combine muliple bodies into one single body?
Question asked by Thijs Vernooij on Feb 6, 2016
Latest reply on Dec 19, 2018 by Alexander Klammer
I have created a single macro to:
1-     Save an assembly as a part.
2-     Opens that part
3-     Selecting all solids inside that part
4-     Combine all bodies                                                  (at this point is get wrong)
5-     SaveOut as an *.STL                                                 (is not yet in this macro)
The weird thing is, he just doesn't do the combine feature. If I let run the delete bodies feature, it worked, but the combine just doesn't work
      Option Explicit
Sub SaveAndOpen(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2)
Dim SwDoc As ModelDoc2
'Dim swApp As Object
Dim sldwrks As SldWorks.SldWorks
Dim Part As ModelDoc2
Dim boolstatus As Boolean
Dim swRootComp As SldWorks.Component2
Dim sPadStr As String
Dim vBody As Variant
Set sldwrks = _
Application.SldWorks
Set Part = sldwrks.ActiveDoc
Dim newfileName As String
newfileName = Part.GetPathName
newfileName = Replace(newfileName, ".sldasm", ".sldprt")
newfileName = Replace(newfileName, ".SLDASM", ".SLDPRT")
Debug.Print newfileName;
longstatus = Part.SaveAs3(newfileName, 0, 0)
Set swApp = _
Set Part = swApp.ActiveDoc
Set Part = swApp.OpenDoc6(newfileName, 1, 0, "", longstatus, longwarnings)
'Set Part = swApp.OpenDoc6("L:\Moogue\DriveWorks\DW-Orders\WebShopBestelling\1187-2455-BHSHUVZVL__-Marjolein Smids_TextSleutelhanger-SLT001_ ID109\1187-2455_2325_-TextSleutelhanger-SLT001----L_Johnny_-R_UwspaceText_-Oranje-_ ID109.SLDPRT", 1, 0, "", longstatus, longwarnings)
'Set Part = Nothing
'Set sldwrks = Nothing
SelectBodies swApp, swModel, vBody, sPadStr
Sub SelectBodies(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, vBody As Variant, sPadStr As String)
    Dim swModExt As SldWorks.ModelDocExtension
    Dim swBody As SldWorks.Body2
    Dim sBodySelStr As String
    Dim sBodyTypeSelStr As String
    Dim i As Long
    Dim bRet As Boolean
    Dim swCombineBodiesFeatureData As SldWorks.CombineBodiesFeatureData
    Dim swFeature As SldWorks.Feature
    Dim status As Boolean
    Dim errors As Long
    Dim warnings As Long
Dim Part As Object
'Dim myFeature As Object
'Su main()
Set swApp = _
    If IsEmpty(vBody) Then Set myFeature = Part.FeatureManager.InsertCombineFeature(swBodyOperationType_e.SWBODYADD, Nothing)          'if you swap those rules, Combino off      ' and deletebody on, you will see that this worked. Why does it not Combine?
    'If IsEmpty(vBody) Then Set myFeature = Part.FeatureManager.InsertDeleteBody2(True)
    If IsEmpty(vBody) Then Exit Sub
    Set swModExt = swModel.Extension
    For i = 0 To UBound(vBody)
        Set swBody = vBody(i)
        sBodySelStr = swBody.GetSelectionId
        Debug.Print "  " & sPadStr & sBodySelStr
        Select Case swBody.GetType
            Case swSolidBody
                sBodyTypeSelStr = "SOLIDBODY"
            Case swSheetBody
                sBodyTypeSelStr = "SURFACEBODY"
            Case Else
                Debug.Assert False
        End Select
        boolstatus = Part.Extension.SelectByID2(sBodySelStr, sBodyTypeSelStr, 0, 0, 0, True, 0, Nothing, 0)
        Set myFeature = Part.FeatureManager.InsertCombineFeature(15903, Nothing, 2)
    Next i
Sub ProcessComponent(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swComp As SldWorks.Component2, nLevel As Long)
    Dim vChildComp As Variant
    Dim swChildComp As SldWorks.Component2
    Dim i As Long
    For i = 0 To nLevel - 1
        sPadStr = sPadStr + "  "
    Next i
    Debug.Print sPadStr & swComp.Name2 & " <" & swComp.ReferencedConfiguration & ">"
    ' Solid bodies
    vBody = swComp.GetBodies2(swSolidBody)
    ' Surface bodies
    vBody = swComp.GetBodies2(swSheetBody)
    vChildComp = swComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        ProcessComponent swApp, swModel, swChildComp, nLevel + 1
    Next i
Sub ProcessAssembly(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2)
    Dim swConfigMgr As SldWorks.ConfigurationManager
    Dim swConf As SldWorks.Configuration
    Set swConfigMgr = swModel.ConfigurationManager
    Set swConf = swConfigMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    ProcessComponent swApp, swModel, swRootComp, 1
Sub Combiner(swApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2)
Dim Part As Object
'Dim Part As ModelDoc2
'Dim boolstatus As Boolean
'Dim longstatus As Long, longwarnings As Long
'Dim swApp As SldWorks.SldWorks
'Dim swModel As SldWorks.ModelDoc2
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeatureMgr As SldWorks.FeatureManager
Dim fileName As String
Dim errors As Long
'Dim Part As Object
    'Set swApp = Application.SldWorks
'    Set Part = sldwrks.ActiveDoc
    'fileName = "C:\Program Files\SolidWorks Corp\SolidWorks\samples\tutorial\multibody\multi_inter.sldprt"
    'Set swModel = swApp.OpenDoc6(fileName, swDocumentTypes_e.swDocPART, swOpenDocOptions_e.swOpenDocOptions_Silent, "", errors, warnings)
    'Set swModel = SldWorks.ActiveDoc
    'Set swModelDocExt = swModel.Extension
    'status = swModelDocExt.SelectByID2("Extrude-Thin1", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
    'status = swModelDocExt.SelectByID2("Boss-Extrude1", "SOLIDBODY", 0, 0, 0, True, 0, Nothing, 0)
    'swModel.ClearSelection2 False
    'status = swModelDocExt.SelectByID2("Extrude-Thin1", "SOLIDBODY", 0, 0, 0, False, 2, Nothing, 0)
    'status = swModelDocExt.SelectByID2("Boss-Extrude1", "SOLIDBODY", 0, 0, 0, True, 2, Nothing, 0)
    'Set swFeatureMgr = swModel.FeatureManager
    'Set swFeature = swFeatureMgr.InsertCombineFeature(swBodyOperationType_e.SWBODYADD, Nothing, Nothing)
    'Set swCombineBodiesFeatureData = swFeature.GetDefinition
    'status = swCombineBodiesFeatureData.AccessSelections(swModel, Nothing)
    'swCombineBodiesOperationType_e:
    ' swCombineBodiesOperationAdd = 0
    ' swCombineBodiesOperationCommon = 2
    ' swCombineBodiesOperationSubract = 1
    'Debug.Print "Type of combine feature: " & swCombineBodiesFeatureData.OperationType
    'swCombineBodiesFeatureData.ReleaseSelectionAccess
'Set myFeature = Part.FeatureManager.InsertCombineFeature(15903, Nothing, Nothing)
'Set myFeature = Part.FeatureManager.InsertDeleteBody2(True)
    Dim i As Long
    Dim bRet As Boolean
    Set swModel = swApp.ActiveDoc
    swModel.ClearSelection2 True
    Debug.Print "File = " & swModel.GetPathName
    Select Case swModel.GetType
        Case swDocPART
            Set swPart = swModel
            ' Solid bodies
            vBody = swPart.GetBodies2(swSolidBody, True)
            SelectBodies swApp, swModel, vBody, ""
            Combiner swApp, swModel
            ' Surface bodies
            vBody = swPart.GetBodies2(swSheetBody, True)
        Case swDocASSEMBLY
            'ProcessAssembly swApp, swModel
            SaveAndOpen swApp, swModel
        Case Else
            Exit Sub
    End Select
The biggest issue is: How do i get different unknown bodies combined in a part. After that, I kan just save it as an STL.
Thanks for your help.
Thijs
