AKAlexander Kibbe05/02/2016
I have a problem where I need to select a solid body in a macro.
Here is a code snippet.  To use this code you FIRST click a surface on any part then run it.  It prompts you for an offset amount and a repetition count then makes that many "shells" around the original surface of the specified thickness.
The problem is the last FOR loop.  It's supposed to select the "thicken"s and set their material independent of the part (and independent of eachother)  the problem is that this code selects them the wrong way.  It selects them as if one clicked on 'thicken#' in the main part tree, but I need it to select as if one had clicked on 'thicken#' inside the 'solidbody' subfolder
    Set Part = swApp.ActiveDoc
    Dim swSurfFeat(50) As SldWorks.Feature
    Dim swThikFeat(50) As SldWorks.Feature
    For x = 1 To TextBox2.Text
    boolstatus = Part.InsertOffsetSurface(TextBox1.Text, False)
    Set swSurfFeat(x) = Part.Extension.GetLastFeatureAdded()
    Next x
    Part.ClearSelection2 True
    swSurfFeat(x).SelectByMark False, 1
    Dim myFeature2 As Object
    Set myFeature2 = Part.FeatureManager.FeatureBossThicken(TextBox1.Text, 1, 0, False, False, True, True)
    Set swThikFeat(x) = Part.Extension.GetLastFeatureAdded()
    Next x
    swThikFeat(x).SelectByMark False, 1
    Part.SetMaterialPropertyName2 "Default", "<location>", "<material>"
    Next x
I know that this sort of code
boolstatus = Part.Extension.SelectByID2("Thicken21", "SOLIDBODY", 0, 0, 0, False, 0, Nothing, 0)
Part.SetMaterialPropertyName2 "Default", "E:/Program Files/SOLIDWORKS Corp/SOLIDWORKS/lang/english/sldmaterials/SOLIDWORKS Materials.sldmat", "Plain Carbon Steel"
Does correctly select the 'solidbody' and then sets its material, but I can't count on knowing the name of the feature.
