Exporting coordinates from a point and transforming the coordinates from sketch to model
Question asked by Thomas Bryant on Feb 5, 2016
Latest reply on Feb 12, 2016 by Thomas Bryant
I would like to create a macro that finds multiple points from multiple 3d sketches and exports the data into a message box and Excel in model coordinates. I've tried various macros online, but none of them seem to compile due to various runtime errors.
I also tried the code in the below links but that did not work either:
https://forum.solidworks.com/thread/91728
Macro to capture points in 3d sketch and export to excel
I always get a "Runtime error 424: Object required" error (or similar ones), whether I try the code in the above link or my code below. Do I have to do something differently in SolidWorks 2016, or is it just overly complicated?
Option Explicit
Dim xlApp As Excel.Application
Dim xlWorkbook As Excel.Workbook
Public Function GetModelCoordinates _
( _
    swApp As SldWorks.SldWorks, _
    swPoint As SldWorks.MathPoint, _
    vPtArr As Variant _
) As Variant
    Dim swMathPt As SldWorks.MathPoint
    Dim swMathUtil As SldWorks.MathUtility
    Dim swMathTrans As SldWorks.MathTransform
    Set swMathUtil = swApp.GetMathUtility
    Set swMathPt = swMathUtil.CreatePoint(vPtArr)
    Set swMathTrans = SldWorks.MathTransform
    Set swMathTrans = swMathTrans.Inverse
    Set swMathPt = swMathPt.MultiplyTransform(swMathTrans)
    GetModelCoordinates = swMathPt.ArrayData
End Function
Sub Main()
    'On Error Resume Next
    Dim vPt1 As Variant
    Dim dArr(2) As Double
    Dim i As Long
    Dim j As Long
    Dim l As Long
    Dim m As Long
    Dim n As Long
    Dim dArrUnit As Variant
    Dim bRes As Boolean
    Dim Message As String
    Dim startRow As Double
    Dim swPoint As SldWorks.SketchPoint
    Dim NumberOfSelectedItems
    Dim swSelBody As SldWorks.Body2
    Dim vModelSelPt1 As Variant
    Dim DEC As Double
    Dim swSketch As SldWorks.Sketch
    Const UnitFactor As Double = 1000 'Get from m to mm
    Set swModel = swApp.ActiveDoc
    Set swSketch = swModel.GetActiveSketch2
    If Not swApp Is Nothing Then
        If Not swModel Is Nothing And Not swMathUtil Is Nothing Then
            NumberOfSelectedItems = swSelMgr.GetSelectedObjectCount2(-1)
            If NumberOfSelectedItems > 0 Then
                'initialize Excel
                Call GetExcel
            For l = 1 To NumberOfSelectedItems
               Set swPoint = swSelMgr.GetSelectionPoint2(l, -1)
               If Not swPoint Is Nothing Then
                   Set swPoint = swPoint.GetPoint2
                   DEC = 6
                   dArr(0) = FormatNumber(swPoint.X, DEC)
                   dArr(1) = FormatNumber(swPoint.Y, DEC)
                   dArr(2) = FormatNumber(swPoint.Z, DEC)
                   vPt1 = dArr
                    vModelSelPt1 = GetModelCoordinates(swApp, swPoint, vPt1)
                        Message = Message & "Coordinates for Centerpoint is " & vbCrLf & "X: " & (vModelSelPt1(0) * UnitFactor) & " mm" & " Y: " & (vModelSelPt1(1) * UnitFactor) & " mm" & " Z: " & (vModelSelPt1(2) * UnitFactor) & " mm" & vbCrLf
                    'write two lines to Excel, so startrow is counted by 2
                    bRes = WriteToExcel(((l - 1) * 2) + 1, vModelSelPt1, "Coordinates from Centerpoint")
            Next l
startRow = 1
    For m = 1 To NumberOfSelectedItems
    For n = 1 To 3 Step 2
    With xlWorkbook.ActiveSheet
    startRow = (4 * m) + n - 2
        .Cells(startRow, 1).Value = "i"
        .Cells(startRow, 2).Value = "j"
        .Cells(startRow, 3).Value = "k"
    End With
    Next n
    Next m
            Set swSelMgr = Nothing
            Set swPoint = Nothing
        Set swModel = Nothing
        Set swMathUtil = Nothing
'show the message
MsgBox Message
Private Sub GetExcel()
    Set xlApp = CreateObject("Excel.Application")
    xlApp.Visible = True
    Set xlWorkbook = xlApp.Workbooks.Add
Private Function WriteToExcel(startRow As Integer, data As Variant, Optional label As String = "") As Boolean
    'get the results into excel
        .Cells(startRow, 1).Value = "X"
        .Cells(startRow, 2).Value = "Y"
        .Cells(startRow, 3).Value = "Z"
        .Cells(startRow, 4).Value = label
        .Cells(startRow + 1, 1).Value = data(0)
        .Cells(startRow + 1, 2).Value = data(1)
        .Cells(startRow + 1, 3).Value = data(2)
    End With
End Function
Thanks for any assistance!
