Has anyone else see this problem or been able to embed 2008edrawings into power point ?
Can I downgrade to 2007?
We are all using edrawings basic 2008 and powerpoint 2003.
This thread is a year old, but I'm hoping for an answer to the same issue.
Can't use edrawings in the Slideshow?
Should have stated earlier, have tried that doesn't work for me, have you had any success with this? Can you post a working example?
I have had some success with this http://www.labnol.org/software/insert-webpages-in-powerpoint-presentations/5108/ and linking to a .htm file created with Edrawings however as soon as I click for the next slide it crashes.
Hi John,
I have Powerpoint 2007sp2 and Edrawings 2009sp5 here.
I can embed and run an edwg in ppt ok.
There seem to be different instructions around for embedding and for various versions but I found the way I did it that .htm actually wasnt needed?...
see below for some clues I found at SW Knowledge base - searched for 'edrawings embed'
HTH
For Powerpoint 2007 you can embed edrawings by:
• In PowerPoint press the Office button and select PowerPoint options.
• On the first option page tick the box called ‘Show developer tab in the ribbon’.
• Now go to the ‘Developer’ tab - go to Macro Security button > enable all macros
• Next select the ‘More controls' button (small hammer and spanner...).
• From the list select ‘eDrawings 2008/9 control’ and click OK.
• Draw a box that will retain the eDrawing on the slide.
• Right Click in the box and select ‘Properties’.
• In properties cut and paste the path to the eDrawings file into the ‘FileName’ field.
Edit OK finally worked out how to cut and paste...
To specify the file, right-click the control (once inserted) and select properties. IN the properties dialog form, in the filename field, there's a button with an ellipsis (...) on it. click that button and a dialog will appear where you specify the path of the file. There's also an elipsis button on this dialog, but when I pressed it, it crashed power point. typing in the path manually did the trick.
I tested the presentation and it looks like it works OK.
John
