Someone try the new option from PDM Professional set revision on a system with 2 revision numbers components?
We have a revision number with 2 revision numbers components and I tried some tests with the option "Set All New Revision Values to Card Variable Value" It does not working at all.
It display a warning message
It is obvious that will not be in list! These 2 revision numbers components are not linear incremented!
In this case (I think) the application must verify that 2 revision numbers components belongs to their lists and also that revision number string is correct and finally set revision variable.
Any idea?
