I modeled the 2 grooves but it took me quite a few steps because of the draft on the side. I was wondering if there is an easier way to do this.i placed all the features in a folder called "Groove Folder". I need to have 1 degree draft for the grooves. Thanks for any help.
Using the flat surface in your image where your pull direction note is located at as the pull direction, your grooves have enough draft for your 1* preference. I don't see the issue or problem. If you are wanting the draft to be normal to the grove path, as if the groove is routed on a mill, then that is a slightly different question.
