Get the third and additional mate for locking rotation.
Question asked by Divyanshu Bhardwaj on Feb 3, 2016
Latest reply on Feb 10, 2016 by Divyanshu Bhardwaj
Hi all,
     I am trying to write a macro for selecting the components (Fasteners inserted though Design Library), and then select the Front plane of the assembly. I want to add parallel mate in this case to lock the rotation of the fastener. I wrote the code as:
Option Explicit
Set swModel = swApp.ActiveDoc
Dim swAssembly As SldWorks.AssemblyDoc
Set swAssembly = swModel
Dim swModelDocExt As SldWorks.ModelDocExtension
Set swModelDocExt = swModel.Extension
Dim swComponent As SldWorks.Component2
Dim sel_count As Integer
Dim sel_type As Integer
'Dim swPlane As Plane
Dim sel_obj As Object
Dim path_name As String
path_name = swModel.GetPathName
Dim assem_name() As String
assem_name = Split(path_name, "\")
Dim new_assem_name As String
new_assem_name = assem_name(UBound(assem_name))
Dim Assembly() As String
Assembly = Split(new_assem_name, ".SLDASM")
Dim assem_name_to As String
assem_name_to = Assembly(0)
Set sel_obj = swSelMgr.GetSelectedObject6(1, -1)
sel_count = swSelMgr.GetSelectedObjectCount2(-1)
Dim i As Integer
Dim sel_comp_name As String
Dim bool As Boolean, Rbool As Boolean
bool = False
Rbool = False
Dim temp As Integer
temp = 0
Dim plane_name As String
Dim swMate As Mate2
Dim error As Long
Dim p_name As String
Dim retbool As Boolean
retbool = False
If sel_count = 0 Then
    MsgBox "You haven't selected anything!!!"
Else
    For i = 0 To sel_count - 1
        bool = False
        bool = swAssembly.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
        If temp <> 0 Then
        sel_type = swSelMgr.GetSelectedObjectType3(1, -1)
        If sel_type = 20 Then
            p_name = "PLANE"
        Set swComponent = swSelMgr.GetSelectedObjectsComponent4(i + 1, -1)
        sel_comp_name = swComponent.Name2()
        plane_name = "Front Plane" & "@" & sel_comp_name & "@" & assem_name_to
        Rbool = swAssembly.Extension.SelectByID2(plane_name, p_name, 0, 0, 0, True, 0, Nothing, 0)
        Set swMate = swAssembly.AddMate4(swMateType_e.swMatePARALLEL, swMateAlign_e.swMateAlignALIGNED, True, 0, 0, 0, 0, 0, 0, 0, 0, False, False, error)
        swAssembly.EditRebuild3
        'swAssembly.Extension.DeleteSelection2 (swDeleteSelectionOptions_e.swDelete_Absorbed)
        'swAssembly.ClearSelection2 True
        Debug.Print sel_comp_name
        Rbool = False
        temp = temp + 1
    Next i
Here What i am trying to do is, select "Front Plane" or "Plane1" of selected component in the assembly, and one "Front Plane" which will be common for main assembly, bring them together and add mate (parallel). Then again in the next go it should pick the appropriate plane from the component and one common front plane from assembly. But my problem is, how to clear the previous selection for component plane without clearing overall selection. After this, if a fastener is inserted at circumference of the rotatory part (Considering, that right now i am inserting the fasteners parallel to the axis of cylindrical part), it should select assembly plane or face as user choice so that once again i bring some mate to constrain the fastener. I don't want to use LOCK MATE or FIX options.
