C# Null Reference - Solidworks Dimension
Question asked by Jason Taylor on Feb 2, 2016
Latest reply on Feb 2, 2016 by Jason Taylor
I am trying to create parts by modifying dimensions on a template part that I have created. I attempted to modify the code from the SolidWorks help website for modifying dimensions with C#. However, I am getting a Null Reference exception when it gets to the line that edits the dimension. Here is the help example I based my code off of: 2013 SOLIDWORKS API Help - Change Dimension Example (C#)
Here is an example of the code I'm trying to use:
        static public void ColdForm()
            var swApp = new SldWorks.SldWorks();
            swApp.Visible = true;
            ModelDoc2 swModel;
            Feature swFeature;
            SelectionMgr swSelMgr;
            Dimension swDim;
            bool boolstatus;
            string filename;
            filename = "C:\\Users\\Jason\\Documents\\Coldform Templates\\10x25z14.sldprt";
            swModel = swApp.OpenDoc(filename, (int)swDocumentTypes_e.swDocPART);
            boolstatus = swModel.Extension.SelectByID2("Hole1Sketch", "SKETCH", 0, 0, 0, false, 0, null, 0);
            swModel.EditSketch();
            swModel.ClearSelection2(true);
            boolstatus = swModel.Extension.SelectByID2("HoleDia1@Hole1Sketch", "DIMENSION",
                                6.02225734887301, 0.182771494811241, -6.62411254208879E-02, false, 0, null, 0);
            swSelMgr = (SelectionMgr)swModel.SelectionManager;
            swFeature = (Feature)swSelMgr.GetSelectedObject6(0, -1);
            swDim = (Dimension)swFeature.Parameter("HoleDia1@Hole1Sketch");
               \\^This is the line VS highlights when it throws the error - specifically (swDim)
            swDim.SetSystemValue2(.01905, (int)swSetValueInConfiguration_e.swSetValue_InThisConfiguration);
            swModel.EditRebuild3();
Full Error message:
An unhandled exception of type 'System.NullReferenceException' occurred
Additional information: Object reference not set to an instance of an object.
I feel like the code is almost an exact copy of the code listed in the help example. Can anyone let me know what I'm doing wrong?
Thanks!
