Macro to save drawing to single PDF and DXF to multiple sheet with Revision
Question asked by Remy Snippe on Jan 31, 2016
Latest reply on Oct 20, 2020 by Md Sobug Mia
Hi all,
Hope some of you are able to help me out with a macro.
Currently I am using two macro's. On to save a drawing to a PDF which includes the property 'Current Revision' in the Filename.
I got the Macro from this website and the only change I had to made was  the Propertyname of the Revision property.
This one runs great and the code is as following:
Dim swApp           As SldWorks.SldWorks
Dim swModel         As SldWorks.ModelDoc2
Dim swDrawModel     As SldWorks.ModelDoc2
Dim swDraw          As SldWorks.DrawingDoc
Dim swView          As SldWorks.View
Dim nErrors         As Long
Dim nWarnings       As Long
Dim Revision As String
Set swDrawModel = swApp.ActiveDoc
If swDrawModel Is Nothing Then
        MsgBox "There is no active drawing document"
        Exit Sub
If swDrawModel.GetType <> swDocDRAWING Then
        MsgBox "Open a drawing first and then TRY again!"
        Exit Sub
Set swDraw = swDrawModel
Set swView = swDraw.GetFirstView
Set swView = swView.GetNextView
Set swModel = swView.ReferencedDocument
If swModel.GetPathName = "" Then
        MsgBox "Insert a View first and then TRY again!"
        Exit Sub
    Revision = swModel.GetCustomInfoValue("", "Current revision")
    If Revision = "" Then
            Revision = ""
    Else
        Revision = "_" & Revision
swDraw.SaveAs3 Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) & Prop & Revision & ".PDF", 0, 0
The second one i use is one I also got from this site and I want to use it to save the drawing to DXF with different Sheets.
It is the following one but it does'nt include the Revision in the Filename. It is naming the file '002001-00-04023_-1_1.DXF' instead of '002001-00-04023_0-1_1.DXF' Note the revionnumber '0'in the filename.
The code is the following:
    Dim vSheetName                  As Variant
    Dim nErrors                     As Long
    Dim nRetval                     As Long
    Dim bShowMap                    As Boolean
    Dim nNumSheet                   As Long
    Dim i                           As Long
    Dim bRet                        As Boolean
    Dim FileName                    As String
Set swModel = swApp.ActiveDoc
' Is document active?
If swModel Is Nothing Then
    swApp.SendMsgToUser2 "A Drawing document must be active.", swMbWarning, swMbOk
    Exit Sub
' Is it a Drawing document?
If swModel.GetType <> swDocDRAWING Then
    Exit Sub
Set swDraw = swModel
' Rebuild the Drawing
    swDraw.ForceRebuild3 (False)
    vSheetName = swDraw.GetSheetNames
    For i = 0 To UBound(vSheetName)
    bRet = swDraw.ActivateSheet(vSheetName(i))
' Zoom to Fit the Sheet
    swDraw.ViewZoomtofit2
'Set File Name Here
    FileName = Left(swDraw.GetPathName, InStrRev(swDraw.GetPathName, ".") - 1) ' Strips off the file extension
    FileName = FileName & "_" & swModel.GetCustomInfoValue("", "Current revision") & "-" & i + 1 & "_" & swDraw.GetSheetCount
    bRet = swModel.SaveAs4(FileName & ".DXF", swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, nWarnings)
    Next i
' Switch back to first sheet
    bRet = swDraw.ActivateSheet(vSheetName(0))
Now my questions are:
1. What is wrong in the DXF code that is failing to write the property 'Current revision' to the filename.
2 Is it possible to combine both macro's into one?
Hope you can help me out on this.
Kind regards
Remy Snippe
