I am working on a stent design for a biomedical application. I have created a 0.2 mm thick flat surface with my pattern.
The total width of the pattern is 2 mm * pi since I want a 2 mm diameter hollow tube with a thickness of 0.2 mm. I would like to wrap this surface so that it forms a cylindrical tube, with both edges merging perfectly together. I am aware of the Wrap feature in SolidWorks but I can't seem to find the right procedure to achieve what I want. After watching a tutorial on YouTube, I saw that in an older version of SolidWorks, the Wrap feature called 2D Sketch and a Planar Face to create a Cylinder. How can I accomplish the same thing in the 2016 version. Cheers!
Two possible methods spring to mind.
1) Use the Flex tool
2) Convert to sheet metal and use the Sketch Bend tool. NOTE: The sheet metal mode will not allow the 'joining' edges to touch. A tiny gap would have to exist.
The Wrap tool is intended for wrapping 2D sketches onto non-planar faces, in preparation for scribing, embossing or debossing.
