Traverse Draw Tree and Hide derived Sketches
Question asked by Hrituc Alexandru on Feb 1, 2016
Latest reply on Feb 2, 2016 by Hrituc Alexandru
I want to hide all derived sketches!. I attached the code that read tree... i try to hide sketches but....error!
thanks!
Option Explicit
Dim traverseLevel As Integer
    Dim myModel As SldWorks.ModelDoc2
    Dim featureMgr As SldWorks.FeatureManager
    Dim rootNode As SldWorks.TreeControlItem
    Set myModel = swApp.ActiveDoc
    Set featureMgr = myModel.FeatureManager
    Set rootNode = featureMgr.GetFeatureTreeRootItem()
    If Not rootNode Is Nothing Then
        Debug.Print
        traverseLevel = 0
        traverse_node rootNode
Private Sub traverse_node(node As SldWorks.TreeControlItem)
    Dim childNode As SldWorks.TreeControlItem
    Dim featureNode As SldWorks.Feature
    Dim componentNode As SldWorks.Component2
    Dim nodeObjectType As Long
    Dim nodeObject As Object
    Dim restOfString As String
    Dim indent As String
    Dim i As Integer
    Dim displayNodeInfo As Boolean
    Dim compName As String
    Dim suppr As Long, supprString As String
    Dim vis As Long, visString As String
    Dim fixed As Boolean, fixedString As String
    Dim componentDoc As Object, docString As String
    Dim refConfigName As String
    displayNodeInfo = False
    nodeObjectType = node.ObjectType
    Set nodeObject = node.Object
    Select Case nodeObjectType
    Case SwConst.swTreeControlItemType_e.swFeatureManagerItem_Feature:
        displayNodeInfo = True
        If Not nodeObject Is Nothing Then
            Set featureNode = nodeObject
            restOfString = "[FEATURE: " & featureNode.Name & "]"
        Else
            restOfString = "[FEATURE: object Null?!]"
    Case SwConst.swTreeControlItemType_e.swFeatureManagerItem_Component:
            Set componentNode = nodeObject
            compName = componentNode.Name2
            If (compName = "") Then
                compName = "???"
            suppr = componentNode.GetSuppression()
            Select Case (suppr)
            Case SwConst.swComponentSuppressionState_e.swComponentFullyResolved
                supprString = "Resolved"
            Case SwConst.swComponentSuppressionState_e.swComponentLightweight
                supprString = "Lightweight"
            Case SwConst.swComponentSuppressionState_e.swComponentSuppressed
                supprString = "Suppressed"
            End Select
            vis = componentNode.Visible
            Select Case (vis)
            Case SwConst.swComponentVisibilityState_e.swComponentHidden
                visString = "Hidden"
            Case SwConst.swComponentVisibilityState_e.swComponentVisible
                visString = "Visible"
            End Select
            fixed = componentNode.IsFixed
            If fixed = 0 Then
                fixedString = "Floating"
            Else
                fixedString = "Fixed"
            Set componentDoc = componentNode.GetModelDoc
            If componentDoc Is Nothing Then
                docString = "NotLoaded"
            Else
                docString = "Loaded"
            refConfigName = componentNode.ReferencedConfiguration
            If (refConfigName = "") Then
                refConfigName = "???"
            restOfString = "[COMPONENT: " & compName & " " & docString & " " & supprString & " " & visString & " " & refConfigName & "]"
        Else
            restOfString = "[COMPONENT: object Null?!]"
    Case Else:
            restOfString = "[object type not handled]"
        Else
            restOfString = "[object Null?!]"
    End Select
    For i = 1 To traverseLevel
        indent = indent & "  "
    Next i
    If (displayNodeInfo) Then
        Debug.Print indent & node.Text & " : " & restOfString
    traverseLevel = traverseLevel + 1
    Set childNode = node.GetFirstChild()
    While Not childNode Is Nothing
        traverse_node childNode
        Set childNode = childNode.GetNext
    Wend
    traverseLevel = traverseLevel - 1
