I would like to re-use a sketch in my model on a different
plane.What is the easiest way to do this?
For those who didn't know this (and I don'tknow if it works every time) if you pick the plane again, it willflip the sketch 180 degrees. I figure this out by trying severalthings because my sketch came in 180 rotated from where I wanted itto be (on the other side of the centerline and mirrored). Thanks,Dale
select sketch you want to copy.
hold ctrl key and select face or plane you want to copy to.
then from insert menu, derived sketch.
the neat thing about this is if you change the sketch you copied from, the copied sketch will also change.
