1 Reply Latest reply on Jan 31, 2016 11:36 PM by Subhra Maiti
    dimension
    Pankaj Bir
      How do you accurately place the dimensions in a sketch
      using the api.
        • Re: dimension
          Subhra Maiti
          Easier way to use swView.Outline to get the outline coordinates, then offset the dimension from the outline.
          the below code describe the above
                  'Get outline coordinate of drawing view 18 in an array called Varr1
                  boolstatus = Part.Extension.SelectByID2("Drawing View18", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
                  SwView = Part.SelectionManager.GetSelectedObject6(1, -1)
                  Varr1 = SwView.GetOutline
                  'Position the dimension RD3@Drawing View18 x=5mm offset from right outline y=middle of view
                  boolstatus = Part.Extension.SelectByID2("RD3@Drawing View18", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
                  myDisplayDim = Part.SelectionManager.GetSelectedObject6(1, -1)
                  swAnn = myDisplayDim.GetAnnotation()
                  boolstatus = swAnn.SetPosition(Varr1(2)+5/1000, (Varr1(1) + Varr(3))  / 2, 0)
          Another more accurate way to transform coordinate from model to drawing view and then position the dimension accordingly.
