hole series problems
Question asked by Chase Draper on Jan 29, 2016
Latest reply on Jan 29, 2016 by Jim Moses
When using hole series in an assembly I cant seem to get the holes to stop at the channel behind the bracket.  It goes thru the housing the channel is welded to and on into the opposite side of the housing.  When i try to set up the hole as blind it continues to do this anyway.  When i select an end component the program crashes.  My Var told me it had to do with it being a multi body part.  Does anyone know a work around or if the problem is solved in 16?  I have 16 but have not started using it yet.
