I have a part file with 10 MB size, i want to increase its size to at least 100 MB for testing purpose of uploading-downloading?
i tried creating random features in it, still size could reach around 20 MB.
As Alin said, a pattern will increase number of faces and thus file size.
Adding configurations will also increase file size. You can do this easily with a design table.
If it's just for bandwidth stressing, then any 100MB file will do the job.
The easiest I've used is MS Paint. Quick and easy to create and adjust, you just have to experiment with the Width and Height values.
You don't need to add anything, just adjust the Width and Height in File>Properties.
Enter 6000 for each and save the default all white file. It's 102MB.
Cheers,
Kevin
Edit: Save as a BMP file.
Hi
Try to save an assembly as a part. My assembly with only a few hundreds of components was saved as a part with 80 MB size. I assume that a bit more complex assembly could be even more than 100 MB
