Hi All,
I have issue with freeze bar and i couldn't fix this. Why is it give this message?
Hi All,
Hard to say exactly what is causing the error message, but if you right click the top line in the tree and select Tree Display > Show Flat Tree View, you may be able to see the problem.
Hello
I had the same problem, delete the folder and it will be ok
SPR 613108 :
Freeze bar cannot roll over a folder containing absorbed features, error, bar cannot be moved to the selected position due to absorbed features
A possible workaround is to delete the folder that contains the feature in order to be able to move freeze bar past the absorbed feature.
Hello
SPR 613108 :
