Delete Waterjet Configuration API help
Question asked by Laura Arns on Jan 28, 2016
Latest reply on Jan 29, 2016 by Laura Arns
The macro ran beautifully a few times, and now it's coming up with an error on the line with PartConfigs = CmpDoc.GetConfigurationNames()
Nobody has changed the macro, and the parts I'm running are similar to the ones I ran before. Before this is run, we've opened an assembly, and run a script to go through each part within it, check for certain material types that would be run on the waterjet, create a waterjet configuration for those parts, undersize certain holes appropriately and suppress certain features within that configuration, then export a DXF of the largest face. When it finds a waterjet configuration already present, it just goes ahead and exports the face without updating for added holes or anything else. This tool is meant to be used in the main assembly, looking at each part within it, and deleting any waterjet configurations within them.
What can change the stability of a macro from one run to the next? How can I change this macro to be more stable? Somebody else did it initially so I'd also appreciate help fully understanding for instance why a temporary assembly needs to be created, or what the "(False)" in "myAsy.GetComponents(False)" is for. Below is the code:
Sub DeleteWJConfigB()
    Dim Assembly As ModelDoc2
    Dim CmpDoc  As ModelDoc2
    Dim myCmps
    Dim i As Long
    Dim myCmp As Component2
    Dim PartConfigs As Variant
    Set swApp = Application.SldWorks 'Tell VBA that you are using SolidWorks
    Set Assembly = swApp.ActiveDoc 'Select the open assembly
    Set myAsy = Assembly            'myAsy is a temporary assembly
'Get all the components in the assembly
myCmps = myAsy.GetComponents(False)
'Cycle through all the components of the assembly
For i = 0 To UBound(myCmps)
    'Temporarily sets myCmp as the "Active" part
    Set myCmp = myCmps(i)
    'Get the model information of the active part
    Set CmpDoc = myCmp.GetModelDoc
    'Get all the configuration names of the active part
    'Macro only runs on parts with more than 1 configuration (this was just to save some time)
    If UBound(PartConfigs) > 0 Then
        'Activate the default configuration (You cannot delete the waterjet config if it is active
        ConfigName = CmpDoc.ShowConfiguration2("Default")
        'Delete the waterjet configuration
        ConfigName = CmpDoc.DeleteConfiguration2("Waterjet")
Next i
'User Feedback
MsgBox ("Operation Complete")
