Good morning,
I am just having an initial look at DimExpert, to see whether it is useful.
My first attempt resulted in it adding a whole load of dimensions, none of which had leading zeros where I wanted them and all of which had trailing zeros where I did not want them (e.g. tolerance +/-.50, rather than +/-0.5).
My document settings result in the format I want when I create a dimension, or when I import drawing items. Only DimExpert seems to do the tolerances differently.
Let's not get into a discussion regarding whether or not what I want is correct to a given standard.
Is it possible to set DimExpert to make tolerances show the way I want? If so, what settings should I change?
SW2014, SP5
Cheers,
John
Hi John,
the DimXpert has it's own settings in the document properties. This may be the reason you dim settings and dimxpert settings differ.
